This is how I bought it last autumn:
I started with working on the steel profiles on the corners. They were a bit rusty so I cleaned and painted them.
Than I took about everything out of the inside and ended up like this:
Than I took out all seatgroups cupboard and kitchen.
Now the whole caravan is empty and its time to repair some weak spots in the floor.
I have desided to make a single bed in the front of the caravan. This gives me a lot of storageroom.
Above this bed there will be a hanging childrens bed.
The big seatgroup in the back of the caravan will be more or less the same.
Taking out the small seatgroup also gives extra space to expand the kitchen.
I desided to take off all wall covering because it was very dirty and damaged.
I fixed some spots in the wall and painted the parts that will end up in the storage departments.
I put a small part of the new floor just to see what it looks like:
After the floor is in topcondition again, I started to prepair the walls for their new covering:
Here is a detailshot:
So this is where I am now. Had to stop because I was out of wallcovering material and the shop was closed.
Today I made a small start with the kitchen. Have bought aluminium profiles to build it.
As soon as I have done more I'll post some pictures.
Grtz, Marc
